Старый 11.01.2009, 10:00   #1
По умолчанию H&R Street/Track Camber Plates for M3
If you have been looking for a camber plate that does it “all”, look no further than the H&R BMW M3 (E46) camber plate. These gems look like they belong on a space shuttle — CNC machined from aircraft grade aluminum billet and finished with Mil spec hard anodizing.
Each steel part is powder coated and stainless hardware is included for beauty and corrosion protection. Having undergone rigorous track testing and stress analyzation, these race-winning camber plates have set the precedent for all others.
The application is compatible with H&R struts and stock struts. Adjustment range is -1.0° to -3.5°, depending upon ride height, and accommodates for the needed strut angle change. To install, simply replace the stock strut bearing with the camber plate assembly.
Race camber plates (with solid spherical bearings) are great for the track, but what if you want to drive your car on the street too? That’s what the H&R street/camber plates are: A plate you can use on the street, still have the available adjustment of a race camber plate, and not have to put up with a harsh ride or replace the bearings every season.
The H&R philosophy is simple and effective: To manufacture the best suspension products, using only the highest grade materials, and then back all of our products with unparalleled customer service. This philosophy has made H&R what it is today - the industry leader in high performance, quality suspension components.
Старый 11.01.2009, 10:51   #2
для Мячково - смое оно. -3.5градусов поставить - и вперед
Старый 13.01.2009, 14:15   #3
bmwz3 m
bmwz3 m has a spectacular aura about
Виталь у тебя же стоят похожие от тейна то?))
bmwz3 m вне форума   Ответить с цитированием
Старый 13.01.2009, 14:27   #4
да. они задействованы для правильного положения... с учетом сход развальных данных
Текущее время: 23:13. Часовой пояс GMT +3.
