Старый 29.10.2011, 01:55   #7
Michelin Pilot Sport CUP
Techn
The MICHELIN Pilot Sport Cup tread pattern
Interior:
- Wet grip oriented
- Grooves and sipes designed for wet handling
Exterior:
- Designed for dry grip
- Extremely stable, Michelin Motorsport derived tread pattern
The MICHELIN Pilot Sport Cup + tread pattern
Interior:
-Full silica compound to optimise wet grip
Exterior:
- Motorsport Compound for outstanding dry grip
- Wider grooves for improved aquaplaning performance
- Additional sipes for improved wet grip
Conditions of Use
  • Road use:
    - Use the car manufacturer’s recommended tyre pressures.
    Track use:
    Cold starting pressures, 26 psi (1.8 bar) front and rear.
    Then bring the tyres gradually up to temperature.
    To maximise grip aim for:
    - Hot pressures of 2.3 bar front and rear (contact Michelin for more information).
    - Tread compound temperature between 70° and 110°C for optimum performance.
    For more information, contact Michelin.
    Important: after track use, before leaving the circuit and once the tyres have cooled down, re-inflate your tyres to establish the car manufacturer’s recommended tyre pressures. Due to the reduced original tread depths and technical characteristics of these tyres, we advise drivers to take care and reduce speeds as necessary in wet conditions, especially in deep standing water or heavy rain. This applies to track and road use.
Тип файла: jpg tread_pattern_2_441x119.jpg (16.7 Кб, 83 просмотров)
Тип файла: jpg tread_pattern_441x119.jpg (65.6 Кб, 86 просмотров)
Метки
03g, a048, advan, зацеп, cup, резина, grip, hard, покрышка, полуслик, medium, слик, состав, pilot, r888, re011s, re11s, slik, soft, sport, v710, wheel, держак
Текущее время: 05:44. Часовой пояс GMT +3.
