Старый 05.02.2008, 13:36   #11
Mad Racer
Аватар для Mad Racer
Mad Racer
...блин, ну ведь задал вопрос про мотор а они опять про тормоза
Старый 05.02.2008, 13:45   #12
Azik
Аватар для Azik
http://www.bmwmregistry.com/model_faq.php?id=15
How is the Euro-spec M3's 3.2-liter engine (S50 B32) different from the previous version (S50 B30)?
When creating the 3.2-liter M3 engine, BMW M relied upon much of the experience it had gained when designing the V12 engine for the McLaren F1 supercar. In the end, the S50 B32 incorporated the following improvements over the S50 B30 engine used in the original Euro-spec E36 M3:
-Increased bore to 86.4mm (from 86.0mm) and lengthened stroke to 91.0mm (from 85.8mm) for a total capacity of 3,201cc (from 2,990cc)
-Increased compression ratio to 11.3:1 (from 10.8:1)
-Advanced BMW/Siemens MSS50 engine management system able to compute 20 million instructions per second
-Double VANOS continuously variable valve timing on both intake and exhaust strokes
-Lightweight pistons
-Improved dual-mass flywheel
-Graphite-coated conrods
-Larger inlet valves
-More efficient intake and exhaust systems
-Second oil pump
The result of these changes boosted horsepower from 286 hp (DIN) at 7,000 rpm to 321 hp (DIN) at 7,400 rpm. Maximum torque also increased from 236 lb/ft at 3,600 rpm to 258 lb/ft at 3,250 rpm. This was the first street-legal BMW engine to achieve over 100 hp per liter.
Текущее время: 21:36. Часовой пояс GMT +3.
