Старый 03.12.2007, 03:02   #3
Kolvir
Kolvir has a spectacular aura about
А ошибка 80 это наверное глюки какие-то, у меня тоже выдаёт 144 и 53, а расшифровки нет!!!
DME 3.3
M60, S38, S50
FAULT MALFUNCTION
0 Undefined Fault
1 Fuel Pump Relay (EKP)
2 Idle Actuator Closing Winding
3 Fuel Injector, #1 Cylinder
4 Fuel Injector, #4 Cylinder
5 Fuel Injector, #6 Cylinder
6 Fuel Injector Output Stage without Cylinder
9 of 32 11/15/00 9:55 AM
bmwcodes http://www.baumtools.com/bmwcodes.htm
Assignment
7 Fuel Injector, #7 Cylinder
8 Fault Lamp (US Model only)
12 Oxygen Sensor #2
13 Oxygen Sensor #1
15 Ignition Circuit Monitoring
16 Crankshaft Pulse Generator
17 Camshaft Sensor
18 Fault to test storage - No actual fault
22 Ignition #7 Cylinder
23 Ignition #6 Cylinder
24 Ignition #4 Cylinder
25 Ignition #1 Cylinder
26 Control Unit Supply B+
29 Idle Actuator Opening Winding
31 Fuel Injector, #5 Cylinder
32 Fuel Injector, #8 Cylinder
33 Fuel Injector, #3 Cylinder
35 Fuel Injector, #2 Cylinder
36 Tank Ventilation
37 Oxygen-Sensor Heater #2
38 Oxygen-Sensor Heater #1
41 Air Mass Flow Sensor (See note 1 page 14.)
42 Road Speed Sensor
46 Free SG Output Stage
48 Air Conditioner Compressor Cutoff
49 Ignition, #2 Cylinder
50 Ignition, #3 Cylinder
51 Ignition, #8 Cylinder
52 Ignition, #5 Cylinder
54 DME Control Unit Power Supply via Main Relay
55 Ignition Final Stage
62 Signal, Electronic Engine Power Control (EML)
63 Torque Convertor Lockup Clutch
64 Engagement in the Ignition Control Unit
65 Air Conditioner Compressor
66 Signal, Burglar Alarm System (DWA)
67 Knock Sensor Cylinder #4
68 Knock Sensor Cylinder #3
69 Knock Sensor Cylinder #2
70 Knock Sensor Cylinder #1
73 Throttle Valve Potentiometer
76 Idle CO Potentiometer
77 Temperature Sensor - Air Intake
10 of 32 11/15/00 9:55 AM
78 Temperature Sensor - Engine Coolant
82 Intervention, Engine Drag Torque Control (MSR)
83 Intervention, Automatic Stability Control (ASC)
85 Air Conditioner Compressor Relay
100 Output Amplifier Stage - Group 1
101 Output Amplifier Stage - Group 2
200 DME control Unit
201 Oxygen Sensor Control #1
202 Fault Memory in Control Unit Fault
203 Oxygen Sensor Control #2
204 Idle Speed Increase During MSR Operation
205 Transmission Intervention during Gear-Shifts
(EGS only)
206 Knock Regulation
210 CAN Interface, Trans. Intervention Version DME
Kolvir вне форума   Ответить с цитированием
Текущее время: 04:56. Часовой пояс GMT +3.
