Старый 04.11.2009, 13:46   #1
По умолчанию F10 BMW M5 2011
Ever since the news broke that the next generation BMW M5 will be powered for the first time by a turbocharged engine, many BMW fans, and not only, have posed THE question: why a turbo engine and not the almighty NA powerplant that made us all happy?
After a discussion with Albert Biermann, head of development at M Division, Autocar UK reports that the decision was influenced by BMW’s aggressive plans to cut fuel consumption as part of the EfficientDynamics programme.
“We’ve been forced to switch to an engine offering greater low-end torque than the naturally aspirated engine to ensure it can cope with the longer axle ratio,” Biermann said. “It’s the only real way we can balance achieving the environmental improvements we want while retaining similar levels of performance to today’s car.”
Could this be a concern? Sure, but if all the past rumors come true, BMW’s use of new technology and even a KERS system will put the new M5 ahead of the current model, both in performance and fuel efficiency. Biermann estimates a 20% cut in CO2 emissions.
Since not all the details can be revealed way ahead of its launch time, the mystery around the engine used remains large. Based on our sources’ reports and what other magazines reported, a V8 twin-turbo engine is the powerplant of choice in the new F10 M5. Output? Unknown, but we expect higher than the 555 ponies outputted by the X5 M and X6 M.
Biermann gets into more details regarding the turbocharged vs. naturally aspirated powerplant. While the 500 horsepower from the current V10 comes at 7,750 rpm, the V8’s highest output should come before 6,000 rpm. But then we have the impressive torque coming from a turbocharged engine. Biermann indicates a 30% increase in torque, so that gives the new M5 around 500 lb-ft of torque at very low rpm.
The added power and V8 turbocharged engine requires additional cooling capacity and current test mules, seen in previous spy photos, are focusing on cooling solutions. The process is still at an early stage.
In the past, we reported that two gearboxes were being considered, an updated 8-speed dual-clutch gearbox (DCT) or a more advanced 8-speed SMG. Although we cannot confirm this at the moment, Autocar reports that the M5 will also get a new gearbox, a beefed-up version of the current M3’s 7-speed DCT. The gearbox was featured last week on the M5 “CSL” at the 25th anniversary event at Nurburgring.
Even though a hybrid model is being considered in the 5 Series line-up, the M5 will not be featuring any sort of hybrid system due to the extra weight would add to the car. Another significant change in the next M5, is the control-arm front suspensions that will replace the MacPherson Struts and at the rear. This will be a multi-link layout.
With a car growing in size, a new large engine, M5’s weight concerns are being addressed by using plenty of carbon fiber design elements. The newly unveiled wind tunnel in Munich will play an important role in the aerodynamics of the new M5. Autocar states that the car will get Active Aerodynamics, which blanks off parts of the grille and cooling intakes during warm-up and under light throttle load.
The F10 M5 will continue to feature different levels of ride comfort, leaving the choice to the driver.
Once again confirming some our previous reports on the new technology available in the next BMW M5, Biermann mentions a new, fully electric power steering that offers similar levels of response and feedback to today’s hydraulic set-up.
The F10 BMW M5 will launch a year after the regular 5 Series models and the 2011 Frankfurt Motor Show would be the perfect venue.
видео проекта на Петле
http://www.youtube.com/watch?v=i4vFDzpvnVU
Старый 04.11.2009, 15:36   #2
Они там совсем рехнулись со своим EfficientDynamics. М5 - это почти суперкар с гигантским ценником, кому какое дело сколько он расходует бензина и сколько выделяет CO2?!?
Насчет коробки тоже не понял. Мотор 4.4ТТ максимальный момент достигается в очень широком диапазоне. Можно использовать небольшие передаточные числа, он и на 4-х ступке нормально поедет. Зачем огород городить с 8-ступенчатой КПП? Ради понтов?
Глянул видео, звук мотора отстой, старый V10 в разы интереснее.
Старый 04.11.2009, 16:00   #3
MishaM3
MishaM3 has a spectacular aura about
Руководитель отдела новых разработок отделения M компании BMW Альберт Бирманн в интервью британскому журналу Autocar раскрыл подробности о "заряженном" автомобиле BMW M5 следующего поколения. Эта машина будет впервые представлена на моторшоу во Франкфурте в 2011 году.
По словам Бирманна, новинка станет оснащаться восьмицилиндровым бензиновым турбомотором, максимальный крутящий момент которого в 678 Нм будет доступен уже с 1500 оборотов в минуту, а уровень выбросов углекислого газа по сравнению с нынешним автомобилем снижен примерно на 20 процентов - с 344 до 275 граммов на километр. Ожидается, что BMW M5 следующего поколения получит 4,4-литровую "восьмерку" с двумя турбинами от BMW X5 M и X6 M, развивающую 555 лошадиных сил и работающую в паре с семиступенчатой роботизированной коробкой передач с двумя сцеплениями. Хотя, характеристики мотора и его мощность официально пока не подтверждены.
Топ-менеджер BMW M GmbH добавил, что в настоящее время первые прототипы нового седана BMW M5, который носит внутрикорпоративное обозначение F10M, построены для испытания того, насколько эффективно измененный дизайн передней части кузова позволяет охлаждать моторный отсек. "Процесс создания этого автомобиля еще находится на начальной стадии. Сейчас мы сосредоточены на надежности и охлаждении силовой установки", - отметил Бирманн.
Ожидается, что M5 следующего поколения также получит агрессивный обвес кузова, карбоновую крышу и багажник (углепластик будет применяться и в каркасе кузова), совершенно новый электроусилитель рулевого управления, активные аэродинамические элементы и специально настроенную для "заряженной" версии систему стабилизации.
Как сообщалось ранее, для нового М5 также будет предлагаться система рекуперации кинетической энергии, которая аналогична той, что сейчас используется на болидах "Формулы-1" - KERS. Ее использование позволит кратковременно увеличить мощность двигателя на 80-85 лошадиных сил за счет подключения электромотора, питающегося от комплекта специальных батарей. Заражаться эти аккумуляторы будут при торможении.
MishaM3 вне форума   Ответить с цитированием
Старый 04.11.2009, 16:37   #4
звук мотора вообще жесть! фу! 4.4ТТ тоже разочаровали... что твориться...
Старый 04.11.2009, 16:41   #5
Сообщение от MishaM3 Посмотреть сообщение
Старый 04.11.2009, 19:02   #6
По мойму эта затея - бред.
интересно, что будет с этой системой после 100-150 использований, да еще в условиях минусовых температур например.
Еще хочется узнать ее ценник.
Когда тестировали КЕРС на Ф1, аккумуляторы иногда взрывались
Старый 05.11.2009, 12:26   #7
Alex505
Так-то оно, может, и так, только вот уже мало кто вспоминает, что когда тестировались первые автомобили, у них иногда паровые котлы взрывались
Думаю, техника не стоит на месте - для того и делают тесты...
Старый 05.11.2009, 22:04   #8
Вадим
Видимо век атомсферных рядных шестерок прошел...
Жаль...
Мне нравилось в ХХ веке....
Старый 13.11.2009, 01:40   #9
Да звук скромненький. ЖАль очень жаль что еще сказать...
Идеология бНв вкорне изменилась.
Старый 14.01.2010, 11:45   #10
Вождь
Так МКПП не ожидается снова?
Текущее время: 19:45. Часовой пояс GMT +3.
